etronicsland MP4 Player Forum
Joined: 31 Aug 2007 Posts: 281 Location: MP4 PlayerLand
Posted: Wed Jan 30, 2008 8:02 am Post subject: How To Replace/Change Battery of Your MP4 Player Nano Clone |
How To Replace Battery of Your MP4 Player Nano Clone
Should your generic MP4 player or iPod clone fail to power up, you can go through these step-by-step instructions on replacing your MP4 player's battery. Note that tampering with the internal parts of your MP4 player will void it's warranty, and etronicsland will not take responsibility for any harm or damage done to the MP4 player.
1. Check the top of your MP4 player. With the screen facing up, you should see a small notch between the two halves of the casing just above and to the right of the USB port.
2. Insert a small screwdriver into the notch and gently pry out the two halves.
3. Through the gap, slip down the side nearest to the notch, pushing apart the clips that hold the device together. Don't snap them off.
4. With the whole of that side detached, lift away the front face half of the MP4 player casing to reveal the insides.
5. Lay down your MP4 player flat on the desk, with the front of the casing facing downwards. The item that you can see on the top of the insides is the battery.
6. Using the screwdriver, carefully lever apart the battery from the rest of the body. Make sure that you are very gentle when doing this.
7. Disconnect the battery entirely by pulling its lead and plug from the socket on the MP4 player's circuit board.
8. Insert your new battery, pressing it onto the spots of glue that secured the original battery cell, then reconnect the power lead.
9. Clip the two halves of your MP4 player case back together, and then plug it in to fully charge up.
10. Do not use your MP4 player until you have fully charged it for at least 4(four) hours, or you could shorten the battery's life. _________________ etronicsland.com
Aigo - Gemei - iSlim - iMax - Teclast - Meizu - JXD - CECT - DEC - Hacha - Onda - TMS - RAmos - OppO - Newsmy/Newman |
