etronicsland MP4 Player Forum
Joined: 31 Aug 2007 Posts: 281 Location: MP4 PlayerLand
Posted: Sun Sep 14, 2008 5:31 am Post subject: How To Update Sunplus SPMP3050 chip MP4/MP5 Players Firmware |
You will Need to use FRM Pro Tools Firmware Update Utility to Update MP4/MP5 firmware.
Note:** Before using FRM Pro Tools, please check your PC computer to confirm that the AP USB driver for your MP4/MP5 player has been installed. If the driver has not been installed, you can download it from our files download section. The driver is found in the 3050 driver directory.
Driver installation method is as follows:
Connect your MP4/MP5 Player SPMP3050 to your PC computer. Your PC will prompt you that it has found a new device. To install the driver, select the 3050 driver folder, and then select ca536av.inf and ca536ai.inf (2 install files). The PC should then proceed through the driver install process. You can click 'finish' at the end.
Now your PC should properly recognize your Sunplus MP4/MP5 player. These are the next steps to take to update the firmware using FRM PRO TOOLS version 1.1.9a:
1. Double-click on the desktop icon of FRM Pro Tools to open the application tool. (DO NOT connect your Sunplus MP4/MP5 player at this time yet.)
2. Right-click on RSV, then select "Set Working Folder" on menu:
3. Choose the corresponding mp4/mp5 model in the "DOWNLOAD" folder path:
4. Right-click on firmware, then select "set file", choose "SPMP3050A.bin"
5. Return to the basic interface, then click on "Dev Detect Begin" :
6. Connect the SPMP3050 device, you can see the LOG window display the word "Detect", then click on "Dev Detect End":
7. If necessary, you can update another SPMP3050 device by simply selecting "DOWNLOAD" again and going through steps 6 and 7, until you have upgraded all devices.
8. Please Note: ** If doing this for the first time, you will have to go through the following 2-step process. So, if that's the case, go to the advanced interface, right-click on the "Working Folder", select "Create RSV Image":
9. In the pop-up interface, select "Enable detect", then click on "Detect blk size":
10. Select the appropriate folder under "DOWNLOAD" folder for the MP4/MP5 device firmware that you want to update. Click the "ISP" button to upgrade it:
11. The tool will start going through the firmware upgrade/update process, and once completed, the "Log Window" will give you a "SUCCESS" display. This means the firmware update "DOWNLOAD" process has completed:
 _________________ etronicsland.com
Aigo - Gemei - iSlim - iMax - Teclast - Meizu - JXD - CECT - DEC - Hacha - Onda - TMS - RAmos - OppO - Newsmy/Newman |
ccimran MP4 Newbie
Joined: 21 Oct 2009 Posts: 1 Location: Faisalabad, Punjab, Pakistan
Posted: Fri Oct 23, 2009 11:29 am Post subject: firmware for my PMP: ATJ2137 |
Sir! please help me in repairing of my PMP which
CPU: ATJ2137
LCD: FPC-HL-240B-QQ
Camera:XHB 7678F
and Board ID: XRD-fo3-V8
My email is *[email removed]* |
Posted: Sun Oct 25, 2009 10:02 am Post subject: |
@ccimran
Please start a new thread describing your problem. _________________ etronicsland.com
chrisluffy25 MP4 Newbie
Posted: Wed Nov 25, 2009 1:03 am Post subject: where is the driver |
where i can find the driver to detect my mp5 by my computer? _________________ hello! |
MP4Guru MP4 Novice
Posted: Sun Nov 29, 2009 8:50 pm Post subject: |
| You can do a search for your driver in the driver downloads section of etronicsland.com. Just do a search for 'driver download' or for the specific driver you want. |
